Function CountColor(InRange As Range, ColorIndex As Long, _ Optional OfText As Boolean = False) As Long ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ' CountColor ' This function counts the cells in InRange whose ColorIndex ' is equal to the ColorIndex parameter. The ColorIndex of the ' Font is tested if OfText is True, or the Interior property ' if OfText is omitted or False. If ColorIndex is not a valid ' ColorIndex (1 -> 56, xlColorIndexNone, xlColorIndexAutomatic) ' 0 is returned. If ColorIndex is 0, then xlColorIndexNone is ' used if OfText is Fasle or xlColorIndexAutomatic if OfText ' is True. This allows the caller to use a value of 0 to indicate ' no color for either the Interior or the Font. ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' Dim R As Range Dim N As Long Dim CI As Long If ColorIndex = 0 Then If OfText = False Then CI = xlColorIndexNone Else CI = xlColorIndexAutomatic End If Else CI = ColorIndex End If Application.Volatile True Select Case ColorIndex Case 0, xlColorIndexNone, xlColorIndexAutomatic ' OK Case Else If IsValidColorIndex(ColorIndex) = False Then CountColor = 0 Exit Function End If End Select For Each R In InRange.Cells If OfText = True Then If R.Font.ColorIndex = CI Then N = N + 1 End If Else If R.Interior.ColorIndex = CI Then N = N + 1 End If End If Next R CountColor = N End Function
For Each r In InRange.Cells If OfText = True Then If r.Font.ColorIndex = CI And r.Value <> "" Then N = N + 1 End If Else If r.Interior.ColorIndex = CI And r.Value <> "" Then N = N + 1 End If End If Next r
COUNTA podľa farby textu
