EXCEL VBA kod porovnanie hodnot v dvoch stlpcoch
Zdravim potreboval by som VB kod ktory by porovnal hodnoty v stlpci "A" s hodnotami v stplci "B" a pokial by sa nachadzala v stlpci "B" hodnata ktora nieje v stlpci "A" tak sa skopiruje do stlpca "A".
Vopred Dakujem
    http://e-xcel.expert E-xcel.expert
    V prilohe subor, kde som aplikoval Vase zadanie. A teda kod porovnava Stplec A a B a v pripade ak sa nerovnaju, tak A=B.
    Kod je tu:
    Sub porovnanie()
    Dim lLastRow As Long
    Dim i As Long
    lLastRow = Cells(Rows.Count, 1).End(xlUp).Row
    For i = 1 To lLastRow - 1
    If Cells(i + 1, 1) = Cells(i + 1, 2) Then
    Cells(i + 1, 4) = "ok"
    Else
    Cells(i + 1, 4) = "zmenene"
    End If
    Next i
    Cells(1, 1).Activate
    End Sub
    excel.sk je offline (nepripojený) excel.sk
    Lektor kurzov Excel excel.sk
    Dobrý deň,
    skúste toto (aj v prilohe):
    Code:
    Sub Z_Becka_Do_Acka_Jedinecne()
        Range("B1").Select
        Range(Selection, Selection.End(xlDown)).Select
        Selection.Copy
        ActiveCell.Offset(0, -1).Range("A1").Select
        Selection.End(xlDown).Select
        ActiveCell.Offset(1, 0).Range("A1").Select
        ActiveSheet.Paste
        Application.CutCopyMode = False
        Columns("A:A").Select
        ActiveSheet.Range("A:A").RemoveDuplicates Columns:=1, Header:=xlNo
        Range("A1").Select
    End Sub
