nikulik Dakujem pekne, ale pri PN aj pri OČR sa v ELDP vypisuje len kolonka KAL.DNI VYL.DôB? Kolonka VZ POčAS VYL.DôB sa nevypisuje vsak?
Z poučenia k ELDP vyplýva, že v položke VZ počas vylúčených dôb sa uvedie:
<style>rmal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} p.MsoBodyText, li.MsoBodyText, div.MsoBodyText {margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:Arial; mso-fareast-font-family:"Times New Roman"; mso-bidi-font-family:"Times New Roman"; color:black; mso-fareast-language:CS;} @page Section1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} /* List Definitions */ @list l0 {mso-list-id:420376453; mso-list-template-ids:-887866174;} @list l0:level1 {mso-level-number-format:alpha-lower; mso-level-text:"%1\)"; mso-level-tab-stop:37.85pt; mso-level-number-position:left; margin-left:31.2pt; text-indent:-11.35pt; mso-bidi-font-family:"Times New Roman";} @list l0:level2 {mso-level-start-at:0; mso-level-number-format:bullet; mso-level-text:-; mso-level-tab-stop:31.2pt; mso-level-number-position:left; margin-left:31.2pt; text-indent:-31.2pt; font-family:"Times New Roman";} @list l0:level3 {mso-level-number-format:roman-lower; mso-level-tab-stop:0cm; mso-level-number-position:left; margin-left:45.0pt; text-indent:-9.0pt; mso-bidi-font-family:"Times New Roman";} @list l0:level4 {mso-level-tab-stop:0cm; mso-level-number-position:left; margin-left:63.0pt; text-indent:-18.0pt; mso-bidi-font-family:"Times New Roman";} @list l0:level5 {mso-level-number-format:alpha-lower; mso-level-tab-stop:0cm; mso-level-number-position:left; margin-left:81.0pt; text-indent:-18.0pt; mso-bidi-font-family:"Times New Roman";} @list l0:level6 {mso-level-number-format:roman-lower; mso-level-tab-stop:0cm; mso-level-number-position:left; margin-left:90.0pt; text-indent:-9.0pt; mso-bidi-font-family:"Times New Roman";} @list l0:level7 {mso-level-tab-stop:0cm; mso-level-number-position:left; margin-left:108.0pt; text-indent:-18.0pt; mso-bidi-font-family:"Times New Roman";} @list l0:level8 {mso-level-number-format:alpha-lower; mso-level-tab-stop:0cm; mso-level-number-position:left; margin-left:126.0pt; text-indent:-18.0pt; mso-bidi-font-family:"Times New Roman";} @list l0:level9 {mso-level-number-format:roman-lower; mso-level-tab-stop:0cm; mso-level-number-position:left; margin-left:135.0pt; text-indent:-9.0pt; mso-bidi-font-family:"Times New Roman";} ol {margin-bottom:0cm;} ul {margin-bottom:0cm;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normálna tabuľka"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
<o:p></o:p>
<!--[if !supportLists]-->
- vymeriavací základ dosiahnutý počas poskytovania vyrovnávacej dávky
a náhrada mzdy z vážnych prevádzkových dôvodov, pre ktoré
zamestnávateľ nemôže prideľovať zamestnancovi prácu - § 142 ods. 4
Zákonníka práce v znení zákona č. 210/2003 Z. z. (predtým § 130 ods. 3 Zákonníka práce).<o:p></o:p>
Tieto sumy je potrebné v súlade s § 138 ods. 1 zákona č. 461/2003 Z. z. v znení neskorších predpisov započítať aj do vymeriavacieho základu uvedeného v rubrike „VZ” (na určenie sumy dôchodku podľa zákona č. 461/2003 Z. z. v znení neskorších predpisov), rovnako ako aj sumu ostatných náhrad mzdy pri prekážkach v práci podľa osobitného predpisu (napr. § 136 až § 144 Zákonníka práce v znení zákona č. 210/2003 Z. z.), ktoré sa v rubrike „VZ počas vylúč. dôb“ neuvádzajú. <o:p></o:p>
