modemom/routerom to asi nebude.
Ak vies, tak skus sa pripojit na router telnetom a dalej je potrebne zistit prikaz na zistenie ADSL informacii.
Ja mam asus a info o ADSL na vystup dostanem cez prikaz
edimax moze mat iny prikaz.
Po zisteni toho prikazu by si mal dostat na vystup nejaku tabulku
Code:
adsl: ADSL driver and PHY status
Status: Showtime Channel: FAST, Upstream rate = 1150 Kbps, Downstream rate = 14
972 Kbps
Link Power State: L0
Mode: ADSL2+
Channel: Fast
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.4 14.7
Attn(dB): 3.0 4.3
Pwr(dBm): 13.0 13.5
Max(Kbps): 23264 1380
Rate (Kbps): 14972 1150
G.dmt framing
K: 47(0) 18
R: 16 16
S: 1 8
D: 0 8
ADSL2 framing
MSGc: 58 13
B: 46 17
B: 46 17
T: 10 7
R: 16 16
S: 0.1002 3.9751
L: 5028 322
D: 256 8
Counters
SF: 3876 3874
SFErr: 0 0
RS: 2481238 32929
RSCorr: 0 17303
RSUnCorr: 0 0
HEC: 0 23
OCD: 0 0
LCD: 0 0
Total Cells: 2212684 667418090
Data Cells: 231 40370164
Drop Cells: 0
Bit Errors: 0 902
ES: 0 0
SES: 0 0
UAS: 31 225
Takze som bol zapoje na kanaly Upstream rate = 1150 Kbps, Downstream rate = 14
972 Kbps a oni mi tvrdili, ze som na kanaly 20 Mbps.
Prip. je mozne to zistit aj cez web iface, ale neviem na 100% ci u vsetkych modemov (vid obr).
Ak ti bude sediet toto (ze budes mat tych 5Mbps, alebo 5000Kbps) tak by to u providera malo byt v poriadku a chybu hladaj u seba.
Urcite nemusis menit router.
Najlepsie je urobit reset routera a nastavit ho na novo.
